The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Opened by Kai Schwebke - 2010-04-09
FS#94 - Unexpected refraction angle in interfaces with changing IOR <> 1.0
I’ve tried to model this setup:
http://kschwebke.webng.com/povray/ior-interfaces/drawing.png with the following SDL:
http://kschwebke.webng.com/povray/ior-interfaces/rs2.pov.txt
A small overlap between the two transparent solids is needed, because a gap
would lead to total reflection. The camera in the test scene looks in the
direction of the ray in the setup drawing. The setup is surrounded with angular
markers, so one can easily read the final resulting looking angle.
POV-Ray 3.6.1 renders the expected result (~53° in the center of the screen):
http://kschwebke.webng.com/povray/ior-interfaces/rs2-35.jpeg
POV-Ray 3.7.0b35a (compiled Unix source) renders a different
(and in my opinion wrong) angle (~67°), however – for the very same scene file:
http://kschwebke.webng.com/povray/ior-interfaces/rs2-37b35a.jpeg
I’ve started a discussion about this issue in povray.beta-test: http://news.povray.org/povray.beta-test/thread/%3Cweb.4bba4677730ab9f3e8c084b40%40news.povray.org%3E/
All linked documents are also attached.
povray-ior-interfaces.zip
Should be mostly fixed with task #4938.
The behavior will still be wrong (and different to 3.6 behavior) when the two objects almost - but not quite - touch each other, with a gap of something around ca. 1e-5 units or smaller. I suspect that overlap in this order of magnitude may still cause unexpected behavior in certain circumstances, too.
Looks like fixed: rendering of original scene is now similar 3.6 when done with 3.7beta38 from source (on amd64)
To render on Ubuntu, I had to install the msttcorefonts package, and add a +L/usr/share/fonts/truetype/msttcorefonts in the command line
(as well as removing the hard coded path of the font in the original scene).
Tested with beta 41.
Updating scene to add #version 3.7; at the start, render is still ok. Can be closed.
