The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
FS#8 - Improve Radiosity "Cross-Talk" Rejection in Corners
Opened by Christoph Lipka (clipka) - Friday, 08 May 2009, 21:10 GMT
DetailsNear concave edges, radiosity samples may be re-used at a longer distance away from the edge than towards the edge; there is code in place to ensure this, but it only works properly where two surfaces meet roughly rectangularly, while failing near the junction of three surfaces or non-rectangular edges, potentially causing “cross-talk”. It should be investigated how the algorithm can be improved or replaced to better cope with non-trivial geometry. |
Christoph, I boldly assume this has been improved with all your radiosity changes?
No, even in its current state Radiosity still offers room for improvement. I don’t intend to address it prior to the 3.7.0 release proper though.
Now tracked on github as issue #249.
