The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Attached to Project: POV-Ray
Opened by Christoph Lipka - 2010-03-26
FS#89 - PPM output garbled for bit depths other than 8 bits
When choosing PPM output with a bit depth other than 8 bits per color channel (e.g. +FP16), POV-Ray messes up the colors (see thread news://news.povray.org:119/4babb48f$1@news.povray.org)
There are actually two separate errors in the code, pertaining to (a) bit depths lower than 8 bpcc, and (b) bit depths greater than 16 bpcc. In both cases the respective formula to convert from floating point to integer is plain wrong.
fixed with change #4932
