POV-Ray
The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Tasklist
FS#70 - load/save photons should be controlled via command line
Attached to Project: POV-Ray
Opened by Christoph Lipka (clipka) - Wednesday, 18 November 2009, 00:38 GMT
Task Type Unimp. Feature/TODO
Category Backend → Photons
Status Tracked on GitHub
Assigned To Thorsten Fröhlich (thorsten)
Operating System All
Severity High
Priority High
Reported Version 3.70 beta 34
Due in Version Undecided
Due Date Undecided
Percent Complete 0%
Votes 2
Private No
Details
Just like radiosity load/save, the photon mapping load/save mechanism should be moved to the frontend and controlled via command-line switch, instead of being SDL-driven in the backend.
This task depends upon
Comment by Christoph Lipka (clipka) - Thursday, 25 August 2011, 19:11 GMT
@thorsten: As you set this to “investigating”, I presume you intend to be the one to do that.
Comment by Thorsten Fröhlich (thorsten) - Thursday, 25 August 2011, 19:18 GMT
Yes, I plan to assuming it isn't implemented yet.
Comment by William F Pokorny (wfpokorny) - Friday, 28 October 2016, 14:17 GMT
  • Field changed: Status (Investigating → Tracked on GitHub)
  • Field changed: Due in Version (3.70 release → Undecided)
Now tracked on github as issue #136.
Loading...
