POV-Ray
The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Attached to Project: POV-Ray
Opened by Jonathon - 2009-08-14
FS#47 - Render Preveiw window can become disabled
If a render is continued with the +c option and the render had completed, the render preview window will disappear and the show/hide render window button will be grayed. Even after the scene is modified and the command line options have been changed, the show/hide button will still be grayed.
Opening or changing to another scene and rendering will not restore the button, nor will rendering with +d. However, if a trace is started using -d, halted, then continued using +d (or allowed to finish completely with -d and a new one is started using +d), then the preview window is restored.
This behavior is different from 3.6.1, which correctly always showed the preview window (since +d is default) unless -d was specified.
William F Pokorny commented on Thursday, 19 January 2017, 14:20 GMT
Now tracked on github as issue #189.
Loading...
Available keyboard shortcuts
Tasklist
Task Details
Task Editing
