POV-Ray
The Persistence of Vision Raytracer (POV-Ray).
This is the Bug Tracking System for the POV-Ray project. Before opening a new task, please read How to make a Bug Report
Please do not issue bugs reports against versions earlier than 3.6.
Tasklist
FS#34 - configure: error: Could not link against boost_thread-boost_thread !
Attached to Project: POV-Ray
Opened by David Ronis (ronis) - Tuesday, 09 June 2009, 17:47 GMT
Task Type Possible Bug
Category Source code → Configure/Build
Status Requires testing
Assigned To Nicolas Calimet (calimet)
Operating System Linux
Severity Critical
Priority Normal
Reported Version 3.7 beta 32
Due in Version 3.7 beta 33
Due Date Undecided
Percent Complete 100%
Votes 0
Private No
Details
I’ve been trying to upgrade povray 3.6.1 to 3.7-beta-32. I’ve configured with no additional arguments, and the configure dies with:
checking whether to build the boost thread library from sources... no
checking for boostlib >= 1.35... yes
checking whether the Boost::Thread library is available... yes
checking for exit in -lboost_thread... no
checking for exit in -lboost_thread-boost_thread... no
I figured that the problem was with my boost installation (1.35) and upgraded boost to 1.39; the problem remains. I tried to see if exit was defined in libboost_thread and/or libboost_thread-boost_thread and it isn’t. Just to be sure that my currrent setup works for the released version, I rebuilt/reninstalled 3.6.1, which went without problem.
I’m on a slackware-12.2 box, using gcc-4.4.0.
This task depends upon
Comment by Nicolas Calimet (calimet) - Thursday, 11 June 2009, 00:05 GMT
Please attach the config.log file.
Comment by David Ronis (ronis) - Thursday, 11 June 2009, 00:33 GMT
The file is attached.
Comment by Nicolas Calimet (calimet) - Monday, 15 June 2009, 20:43 GMT
Please try the attached configure file in place of that coming with beta.32.
Comment by David Ronis (ronis) - Monday, 15 June 2009, 21:01 GMT
The new configure still dies:
checking for boostlib >= 1.36... yes
checking for exit in -lboost_thread-gcc44-mt-1_39... yes
checking whether the boost thread library is usable... no
configure: error: in `/home/ronis/povray-3.7.0.beta.32':
configure: error: cannot link with the boost thread library
See `config.log' for more details.
ls -l prefix/libboost_thread* shows:
ls -l /usr/local/lib/libboost_thread-gcc44-mt*
-rw-r–r– 1 root root 132210 2009-06-09 13:24 /usr/local/lib/libboost_thread-gcc44-mt-1_39.a
lrwxrwxrwx 1 root root 39 2009-06-09 13:24 /usr/local/lib/libboost_thread-gcc44-mt-1_39.so → libboost_thread-gcc44-mt-1_39.so.1.39.0*
-rwxr-xr-x 1 root root 77812 2009-06-09 13:24 /usr/local/lib/libboost_thread-gcc44-mt-1_39.so.1.39.0*
lrwxrwxrwx 1 root root 31 2009-06-09 13:24 /usr/local/lib/libboost_thread-gcc44-mt.a → libboost_thread-gcc44-mt-1_39.a
lrwxrwxrwx 1 root root 39 2009-06-09 13:24 /usr/local/lib/libboost_thread-gcc44-mt.so → libboost_thread-gcc44-mt-1_39.so.1.39.0*
So the library is there.
I've attached config.log
Comment by David Ronis (ronis) - Monday, 15 June 2009, 21:12 GMT
I manually copied the conftest to a file and ran the g++ command as indicated in the log.
/usr/bin/g++ -o conftest -march=pentium4 -msse2 -mfpmath=sse -O3 -ffast-math -funroll-loops -fomit-frame-pointer -floop-interchange -floop-strip-mine -floop-block -pthread -pthread -I/usr/local/include -L/usr/local/lib boost.cc -lboost_thread-gcc44-mt-1_39 -pthread
{ronispc:158} echo $?
0
It still died when I ran it (same error message). It turns out that I'd forgotten to run ldconfig after upgrading boost. When I do configure finishes without complaint. The build dies either as:
make
make all-recursive
make[1]: Entering directory `/home/ronis/povray-3.7.0.beta.32'
Making all in libraries
make[2]: Entering directory `/home/ronis/povray-3.7.0.beta.32/libraries'
make[2]: * No rule to make target `all'. Stop.
make[2]: Leaving directory `/home/ronis/povray-3.7.0.beta.32/libraries'
make[1]:
* [all-recursive] Error 1
make[1]: Leaving directory `/home/ronis/povray-3.7.0.beta.32'
make: *** [all] Error 2
Comment by Nicolas Calimet (calimet) - Monday, 15 June 2009, 21:51 GMT
config.log: yes it was clear that you had a run-time check problem that you solved running ldconfig.
For the last make problem: this is expected as some changes have been made in the Makefile.am templates (basically the libraries/ folder is gone in the next beta).
Try to edit the povray-3.7.0.beta.32/Makefile.in (or Makefile.am if you can run the bootstrap script) to remove all references to "libraries", and configure && make again.
Comment by David Ronis (ronis) - Monday, 15 June 2009, 22:49 GMT
Ok, removing the library references in Makefile.in and rerunning configure gets me much farther. The build still dies though with:
unix/unixconsole.cpp: In function 'void PrintVersion()':
unix/unixconsole.cpp:318: error: 'BUILTIN_SVGA_DISPLAY' was not declared in this scope
make[2]: *** [unixconsole.o] Error 1
Comment by Nicolas Calimet (calimet) - Tuesday, 16 June 2009, 08:50 GMT
Well, support for the SVGA lib is also dropped in the next beta. You can safely remove all references to it as well.
I'll be sending you a test version of beta.33 by mail in case you keep hitting this kind of non-issues.
Comment by David Ronis (ronis) - Tuesday, 16 June 2009, 16:54 GMT
OK, I deleted the reference to BUILTIN_SVGA_DISPLAY in unixconsole.cpp and can compile further. Now it dies with:
/usr/bin/g++ -pipe -Wno-multichar -Wno-write-strings -fno-enforce-eh-specs -s -O3 -ffast-math -malign-double -march=native -march=pentium4 -msse2 -mfpmath=sse -O3 -ffast-math -funroll-loops -fomit-frame-pointer -floop-interchange -floop-strip-mine -floop-block -pthread -L/usr/local/lib -L/usr/lib -o povray disp_sdl.o disp_text.o ../vfe/libvfe.a ../source/backend/libbackend.a ../source/frontend/libfrontend.a ../source/base/libbase.a ../source/libpovray.a @LIBBOOST_THREAD@ -lSDL -L/usr/lib -Wl,-rpath,/usr/lib -lSDL -lpthread -lXpm -lSM -lICE -lX11 -lIlmImf -L/usr/local/lib -lIlmImf -lImath -lHalf -lIex -lz -lIlmThread -ltiff -ljpeg -lpng12 -lz -lrt -lm -lboost_thread-gcc44-mt-1_39 -pthread
g++: @LIBBOOST_THREAD@: No such file or directory
@LIBBOST_THREAD@ should be replaced by the actual -lxxx library directive, no?
Comment by David Ronis (ronis) - Tuesday, 16 June 2009, 17:01 GMT
I manually put in the boost library into unix/Makefile and removed @LIBBOOST_THREAD@. Everything compiles now. Whew!
However, make check gives:
./unix/povray +i./scenes/advanced/biscuit.pov -f +d +p +v +w320 +h240 +a0.3 +L./include
povray: this pre-release version of POV-Ray for Unix has expired
make: *** [check] Error 1
Sheesh, I finished compling a minute ago. :)
Thanks for your help.
Comment by Nicolas Calimet (calimet) - Tuesday, 16 June 2009, 20:31 GMT
Use the expiry extension feature for now.
Comment by David Ronis (ronis) - Tuesday, 16 June 2009, 21:45 GMT
That did it. Again, thanks for your help.
Comment by Grimbert Jérôme (Le_Forgeron) - Tuesday, 22 September 2009, 07:09 GMT
Beware: current (beta 34) configure checks "checking for boostlib >= 1.36"
Despite the words on the beta page about 1.37 (which should be ok)
Please update configure to check > 1.36, or >= 1.37
Loading...
