The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Opened by Christoph Lipka - 2013-08-20
FS#304 - #for-loop may fail to perform last iteration
Using an end value of 1048576 or larger in a #for loop will cause the last iteration to be skipped, as can be demonstrated by the following code:
#declare N = 2000000;
#debug concat(”N = “,str(N, 0,50),”\n”)
#debug concat(”N-5 = “,str(N-5,0,50),”\n\n”)
#for (I, N-5, N, 1)
#debug concat("I = ",str(I,0,50),"\n")
(The limit was observed with a Win64 build; other builds may exhibit other limits or might even work fine, depending on the floating point engine used.)
As this limit is still far below the numeric precision limit, and a corresponding #while loop works fine with much higher values, this must be considered a bug rather than an inevitable limitation.
The bug can be tracked down to a faulty condition in tokenize.cpp, Parser::Parse_Directive(), CASE(END_TOKEN), case FOR_COND:
if ( ((Step > 0) && (*CurrentPtr >= End + EPSILON)) ||
((Step < 0) && (*CurrentPtr <= End - EPSILON)) )
which should instead be:
if ( ((Step > 0) && (*CurrentPtr > End + EPSILON)) ||
((Step < 0) && (*CurrentPtr < End - EPSILON)) )
Saturday, 10 December 2016, 15:14 GMT
Reason for closing: Fixed
Additional comments about closing:
Tests of 3.7 RC7, 3.7.0 and 3.7.1 show
the fix in 3.7.0 onward.
fixed with change #6008
