The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Opened by William F Pokorny - 2013-06-05
FS#294 - Thread safety issue in functions using splines. 3.7.0.RC7.
First vetting in p.bugreports where several users were able to reproduce the fail on the following systems:
1) Ubuntu 12.1 i7 920 using 3.7.0.RC7
2) Ubuntu 12.04, AMD 2431 CPU, Linux 3.2.0-45 kernel using 3.7.0.RC7 (g++ 4.6 @x86_64-unknown-linux-gnu)
3) POV-Ray 3.7.0.RC7 (icpc 13.1.0 @x86_64-unknown-linux-gnu)
Intel(R) Xeon(R) CPU E5-2680 0 @ 2.70GHz
uname -or 2.6.32-279.14.1.el6.x86_64 GNU/Linux
lsb_release -irc Distributor ID: CentOS Release: 6.3 Codename: Final
4) Confirmed with openSUSE 12.2.
5) Just to add to the system list: with Windows and a core i7 one yields the same result.
6) “Le_Forgeron” ran under Intel Inspector (XE 2013) and provided this feedback :
... that might be less than 60 seconds, but with Intel Inspector (XE 2013), it becomes 42:50 (just 14 data races, oh well, that's just so friendly).
ID Type Sources Modules State P1 Data race isosurf.cpp; mutex.hpp povray New P2 Data race mutex.hpp; povms.cpp povray New P3 Data race povray.cpp povray New P4 Data race povray.cpp povray New P5 Data race mutex.hpp; pov_mem.cpp; splines.cpp povray New P6 Data race mutex.hpp; pov_mem.cpp; splines.cpp povray New P7 Data race mutex.hpp; pov_mem.cpp; splines.cpp povray New P8 Data race recursive_mutex.hpp; scene.cpp; task.cpp; taskqueue.cpp; view.cpp povray New P9 Data race condition_variable.hpp; vfe.cpp; vfesession.cpp povray New P10 Data race condition_variable.hpp; unixconsole.cpp; vfesession.cpp povray New P11 Data race condition_variable.hpp; unixconsole.cpp; vfesession.cpp povray New P12 Data race unixconsole.cpp; vfesession.cpp; vfesession.h povray New P13 Data race unixconsole.cpp; vfesession.cpp povray New P14 Data race [Unknown]; unixconsole.cpp; vfesession.cpp libboost_thread.so.1.49.0; povray New
Numbers 2, 3, 4, 8, 9, 10, 11, 12, 13 & 14 are related to the handling of session (and occur once or twice only, excepted #8, four times).
Number 1 is about isosurface (adjusting gradient at isosurf.cpp:1099 vs 1098 (testing its value), and copying the isosurface) (IMHO, rendering threads updating the object... not the best move without some atomic/protection (and not sure a DBL is/can be atomic)) (occurs 2505 times).
Number 5, 6 and 7 are about splines * sp->Cache_Type & Cache_Point, splines.cpp :803 vs :814/815 (2024 times) * sp->Cache_Valid, :805 vs :813 vs :904 (1770 times) * sp->Cache_Data, :807 vs :903 (5025 times)
Only my 0.02¢ (yes, very cheap), but it seems to confirm
For test code see attached files or SplineThreadSafety.pov attachment to
p.bugreports and images were posted to p.b.images.
Issue shows up any time more than one thread is used. Use of AA tends to hide
the problem so do not use it if using the output image for testing.
Thanks.
Bill P.
Tuesday, 11 October 2016, 13:25 GMT
Reason for closing: Fixed
Additional comments about closing:
Verified fixed in 3.7.0 and our current
3.7.1 master branch. Also looks to me
like the cache code was removed and not
just disabled.
Missing magic from description:
Experimenting with the code of spline, 1 thread, gcc compiler:
3.7RC7 code (instrumented with 2 extra size_t):
Cachectomised spline code (no caching, smaller structure)
Despite being useful to avoid computation of the spline again, the cache is slower than the direct computation (at least on this scene).
I would vote for removing that cache of the spline.
Fixed with change 5907.
