POV-Ray
The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Tasklist
FS#275 - circular area lights exhibit anisotropy
Attached to Project: POV-Ray
Opened by Christoph Lipka (clipka) - Saturday, 09 March 2013, 02:53 GMT
Last edited by William F Pokorny (wfpokorny) - Saturday, 28 January 2017, 16:01 GMT
Task Type Definite Bug
Category Backend → Light source
Status Tracked on GitHub
Assigned To Jim Holsenback (jholsenback)
Operating System All
Severity Low
Priority Normal
Reported Version 3.70 RC7
Due in Version Future release
Due Date Undecided
Percent Complete 50%
Votes 0
Private No
Details
circular area lights exhibit some anisotropy, being brighter along the diagonals than on average, as can be demonstrated with the following scene:
//+w800 +h800
#version 3.7;
global_settings{assumed_gamma 1}
plane{-z,-10 pigment{rgb 1} finish{ambient 0 brilliance 0}}
disc{0,z,10000,0.5}
camera{orthographic location z look_at 10*z up y*12 right x*12}
light_source{-10*z rgb 10 area_light 10*x 10*y 257 257 adaptive 4 circular}
This task depends upon
Comment by Simon (infoised) - Wednesday, 13 March 2013, 16:01 GMT
Not surprising, currently the rectangular grid of sample lights is just deformed into a circle, which makes the lights more dense along diagonals (see figure). I see no reason to stick with the rectangular array of lights. The expensive part is testing for shadows, but the sampling lights could be arranged in many ways:
usual polar coordinates (denser at the center, but isotropic)
polar coordinates with uniformly increasing number of lights with radius (best)
Halton-like sub-random sequence for incremental sampling (like radiosity)
All these algorithms have a problem that they are harder to use with adaptive sampling (neighbouring lights are not easy to find, and they are not in fours, so oversampling is difficult). Circular lights would need a separate adaptive algorithm. The easiest solution would probably be to triangulate and subdivide the triangles. Triangulation could also be expanded to the concept of mesh lights.
A lazy solution is to keep current distribution of lights, and calculate dimming factors to make the illumination uniform. However, the lights still have larger resolution at diagonals, and dimming wastes accuracy (optimal sampling solution has equal weights of all the lights).
Comment by Simon (infoised) - Wednesday, 13 March 2013, 18:09 GMT
If I'm not mistaken, the density of lights goes as 1/cos(phi)^2 if phi is the polar angle: tan(phi)=y/x, if abs(x)>abs(y), and 1/sin(phi)^2 if abs(x)<abs(y), making the light density at diagonals precisely double than density at the horizontal and vertical line. A "patch" can therefore be done by multiplying each light intensity by
max(x,y)^2/(x^2+y^2)
and normalization of the all the weights, so that the sum of the intensities is still the same as expected.
However, I'm not entirely sure about this, it's a quick calculation.
Comment by Christoph Lipka (clipka) - Thursday, 14 March 2013, 10:19 GMT
Thanks for your feedback, Simon. Here are a few more thoughts of mine:
  • The non-adaptive non-circular area light is a fixed array of lights, so for consistency the non-adaptive circular version should also be; that rules out Halton sampling.
  • The adaptive non-circular area light algorithm is based on systematic subdivision of the area, so for consistency the adaptive circular version should also be; such a systematic subdivision could certainly be used in a non-adaptive manner as well, so I think there's no reason to invest coding time into an independent non-adaptive approach.
  • The code for the quadrilaterals-based subdivision approach is well-established, well-tested, and very straightforward; a triangles-based approach would probably be a bit more difficult, and would have to be written from scratch.
My idea would therefore be to just fix the formula that deforms the square into a circle, so that the points in each of the concentric circles end up spaced evenly. I guess this will involve some use of trigonometrics, which may degrade performance, but if it turns out to be too bad we could simply pre-compute the deformation factors (sharing the table among area lights with the same number of subdivisions).
Comment by Simon (infoised) - Thursday, 14 March 2013, 18:59 GMT
Fixing the formula would be very difficult, if not practically impossible. It probably won't be just simple trigonometry (I had a similar problem before, it wasn't pretty). To make the density uniform, points have to rearrange in both dimensions (lights from the diagonals have to be pushed apart sideways and radialy at the same time), and finding a useful analytical formula is probably not worth the effort.
If you want to keep the quadrilateral adaptive algorithm, there are a few options:
  • Subdivision of triangles into 3 quadrilaterals (complicated, and generates more points even before subdivision).
  • Merging two triangles into quadrilateral (easier, but for a chosen triangulation, the pairs have to be chosen carefully).
Both solutions would require precomputing the points and arrays of indices for each quadrilateral, because indexing is very difficult (basically you are constructing a mesh). This can be done at parse time (storing around 30 vectors for each light and a couple of integers is not too much).
Personally, I would choose the construction with one point in the middle, N points in the next layer, 2N points in the third layer, 3N, 4N,... like this
http://www.photo-dictionary.com/photofiles/list/1762/2325pasta_strainer.jpg (just not on straight hexagonal lines but on circles)
If you can then group the triangles into quads and store them in an array, it's done (but not easy).
Comment by Christoph Lipka (clipka) - Thursday, 14 March 2013, 20:51 GMT
I'm well aware that achieving equal distances both radially and circumferentially is an absolute impossibility, but I'm just aiming at circumferentially uniform spacing. This should be rather trivial: All you need to do is interpret the square grid not as an array of NxN points, but as N/2 concentric square frames of 4(i-1) points each (for even N), or (N-1)/2 concentric square frames of 4(i-1) points each with one additional point in the center (for odd N); obviously you can arrange the 4(i-1) points of any of the square frames in a circular fashion with equal circumferential distances instead, and this circumferential distance will be the same for all nesting levels; likewise, the radial distance between any such circle and the one immediately nested within will also be the same for all circles (albeit different from the circumferential distance).
Those options are far from the current adaptive algorithm, which is based around the property that the mesh formed by the quadrilaterals is topologically equivalent to a simple NxN grid.
Actually what my suggestion would result in is exactly that (for odd number of elements squared), with N=4 (instead of N=6 as you probably have in mind).
Comment by Simon (infoised) - Thursday, 14 March 2013, 22:09 GMT
Perfect, this is excellent (actually it's N=8), I should have seen it before - the merging of triangles is obvious and gives exactly the topology of the grid. And it actually has constant average density (which is more important than equal radial and circumferential spacing, which you get in hexagonal grid).
Comment by William F Pokorny (wfpokorny) - Saturday, 28 January 2017, 16:01 GMT
  • Field changed: Status (New → Tracked on GitHub)
Now tracked on github as issue #222.
Loading...
