The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Pertenece al proyecto: POV-Ray
Abierta por Christoph Lipka - 2013-01-20
Ultima edición por Christoph Lipka - 2013-08-21
FS#266 - command line options in ini files don't accept quoted strings as parameters
Quoted strings as parameters to command-line options work on the command line but not in INI files; e.g.:
+i"test.pov"
Root cause has already been identified (actually the problem was found during code inspection) and a fix is under way.
Cerrada por Christoph Lipka
Wednesday, 21 August 2013, 13:23 GMT
La razon de cierre es: Fixed
Comentarios adicionales sobre el cierre:
No news for half a year now; presumably
fixed for good.
fixed with change #5743
