The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Opened by Grimbert Jérôme - 2013-01-11
FS#265 - Warnings from clang that might need consideration
Compiling the sources with clang instead of g++ (on ubuntu 12.10 with boost 1.50)
./configure COMPILED_BY=”your name here <also@email>” LIBS=-lboost_system –disable-io-restrictions CC=clang CXX=clang
there is a few warnings that catch the eyes (and other as well that I dismiss so far, such as cases not covered in switch and empty body in if, or extraneous parentheses in tests):
support/randomsequences.cpp:553:15: warning: field is uninitialized when used here [-Wuninitialized]
startIndex(startIndex)
support/randomsequences.cpp:974:40: note: in instantiation of member function 'pov::PrecomputedNumberGenerator<int>::PrecomputedNumberGenerator' requested here
SeedableIntGeneratorPtr generator(new PrecomputedIntGenerator(factory, count));
support/randomsequences.cpp:984:43: note: in instantiation of member function 'pov::PrecomputedNumberGenerator<double>::PrecomputedNumberGenerator' requested here
SeedableDoubleGeneratorPtr generator(new PrecomputedDoubleGenerator(factory, count));
support/randomsequences.cpp:1011:43: note: in instantiation of member function 'pov::PrecomputedNumberGenerator<pov::Vector3d>::PrecomputedNumberGenerator' requested here
return SequentialVectorGeneratorPtr(new PrecomputedVectorGenerator(factory, count));
support/randomsequences.cpp:1056:45: note: in instantiation of member function 'pov::PrecomputedNumberGenerator<pov::Vector2d>::PrecomputedNumberGenerator' requested here
return SequentialVector2dGeneratorPtr(new PrecomputedVector2dGenerator(factory, count));
Self referencing member in creator does not seems to be great for a reproducible pseudorandom generator (some compiler/architecture might force to 0, other might not... seems bad karma).
povmscpp.cpp:1875:4: warning: delete called on 'POVMS_MessageReceiver::HandlerOO' that is abstract but has non-virtual destructor [-Wdelete-non-virtual-dtor]
delete nodeptr->handleroo;
povmscpp.cpp:1877:4: warning: delete called on 'POVMS_MessageReceiver::Handler' that is abstract but has non-virtual destructor [-Wdelete-non-virtual-dtor]
delete nodeptr->handler;
Maybe just a missing keyword (virtual) in the header file ? Or is it harder ?
shelloutprocessing.cpp:260:28: warning: expression result unused [-Wunused-value]
for (s = str.c_str(); *s; *s++)
Why “*s++” ? why not just “s++” ?
renderfrontend.cpp:1165:57: warning: trigraph ignored [-Wtrigraphs]
default: t = "(???)"; break;
I guess it’s not an intended trigraph. Might nevertheless perturb some compiler/result.
Friday, 25 November 2016, 15:48 GMT
Reason for closing: Fixed
Additional comments about closing:
In a clang compile of 3.7.1 master Nov 23, 2016 none of the warnings here are now present; though, there are a few other minor ones.
We are today regularly doing clang
compiles and I suggest we address new
clang warnings on github or in code as
we see them.
Oops, yes, indeed. No harm done though, as
startIndexisn't used anywayI'll submit a fix. I'm also taking care of the trigraph in renderfrontend.cpp.
povmscpp.cpp:1875:4: warning: delete called on 'POVMS_MessageReceiver::HandlerOO' that is abstract but has non-virtual destructor [-Wdelete-non-virtual-dtor] delete nodeptr->handleroo; ^ povmscpp.cpp:1877:4: warning: delete called on 'POVMS_MessageReceiver::Handler' that is abstract but has non-virtual destructor [-Wdelete-non-virtual-dtor] delete nodeptr->handler; ^No need to worry about these two. The classes use is strictly controlled (a private definition in its parent class definition) has only automatically generated destructors and contains only POD types, so the destructors will always be empty code (and should end up being optimized away). The only way to make this warning go away in this case would be to add empty destructor code in all six classes, which seems excessive. The classes can't get extended or inherited from anywhere else than in this narrow piece of code.
