The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
FS#238 - Error during #read causes file to be kept open
Consider the following script:
#fopen F "foo.txt" read
#read (F, Foo)
#debug concat ("'", Foo, "'\n")
#fclose F
Now assume that foo.txt erroneously contains unquoted text (which will result in a parse error):
Blah
When the error is reported, POV-Ray for Windows will helpfully open foo.txt, but any attempt to save a corrected version of foo.txt will fail until you exit the POV-Ray GUI, presumably because foo.txt is not properly closed by the parser.
Fixed in change 5715.
