POV-Ray
The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Attached to Project: POV-Ray
Opened by Grimbert Jérôme - 2011-08-20
FS#217 - raddem.ini with +C and some frames already done: failure
How to do it: (with raddem.ini & raddem.pov from distributed scenes, copied in local directory)
1. run “povray raddem.ini” until frame 6 or more (irrelevant, at least frame 1 & 2 are needed), interrupt the render.
2. restart “povray raddem.ini +C”
It fails at frame 2 with
Possible Parse Error: Cannot find file ‘raddem.pov’, even after trying to append
file type extension.
Parse Error: Cannot open input file.
Fatal error in parser: Cannot parse input.
Render failed
The detection of frame 1 is fine.
Closed by  Chris Cason
Tuesday, 04 September 2012, 22:18 GMT
Reason for closing:  Fixed
Grimbert Jérôme commented on Friday, 14 October 2011, 12:39 GMT
Duplicated on Windows with 3.7RC3:
1. Ini, browse to scenes/animation/raddem/raddem.ini
(notice: Radiosity line must be removed or set in comment)
2. close all scenes tab.
3. Run
4. stop once a few images have been rendered
5. Put "+C" in the command line text-box (without the quotes)
6. Run
and it fails at the same step (frame 2 does not find the raddem.pov file)
Grimbert Jérôme commented on Tuesday, 01 May 2012, 12:04 GMT
Testing with 3.7RC5 on linux: problem is gone.
Loading...
Available keyboard shortcuts
Tasklist
Task Details
Task Editing
