The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Opened by Christoph Lipka - 2011-06-04
FS#210 - UV mapping broken for parametric
UV-mapped textures for parametrics are broken in POV-Ray 3.70 RC3, in cases where two (or more) parametrics overlap in a scene.
In the following scene, note how the texture per se is always taken properly from whichever parametric is in front, while the UV coordinates are erroneously taken always from the red parametric where both overlap, no matter whether it is in front or back.
location <0.0, 1.5, -3.0>
direction 1.5*z
look_at 0
light_source { <-30, 30, -30> color rgb 1 }
#declare Param = parametric {
function { u*v*sin (15*v) },
function { v },
function { u*v*cos (15*v) }
0, 1
contained_by { box { -1,1 } }
accuracy 0.002
precompute 15 x,y,z
rotate 180*x
translate <0.3,0.5,0>
object {
Param
uv_mapping
gradient x frequency 3
color_map {
[0 color red .5 ]
[1 color red 1 ]
object {
Param
uv_mapping
gradient x frequency 7
color_map {
[0 color green .5 ]
[1 color green 1 ]
rotate y*180
POV-Ray 3.62 renders the scene properly.
As this bug has been found during code inspection, the uderlying cause has already been identified; I’m currently working on a fix.
fixed with change #5450
