The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Attached to Project: POV-Ray
Opened by Kerry Tyler - 2011-04-02
FS#199 - typos in sample scenes prevent render
.../scenes/objects/fractal2.pov
in global_settings "max_trace" should be "max_trace_level"
.../scenes/advanced/diffuse_back.pov
in global_settings assumed_gamma statement should not be followed by a semicolon
.../scenes/advanced/blocks/stackernight.pov
in global_settings "assummed_gamma" should be spelled "assumed_gamma"
.../scenes/portfolio/*.pov
in all files other than _empty.pov the parse stops at the lines containing "[frame_number-1]" I'm guessing it should be "[frame_number]-1"
Closed by Christoph Lipka
Thursday, 21 June 2012, 23:03 GMT
Reason for closing: Fixed
Additional comments about closing:
no news, so I guess the fix was
effective
Corrected reported typos in scene files, however I could not confirm the problem reported with the portfolio scene files. If I’m not mistaken they are to be run as if they were an animation. While cd’ed to the portfolio directory I was able to run ALL of the ini files to completion.
For example:
povray allpatterns.ini
