POV-Ray
The Persistence of Vision Raytracer (POV-Ray).
This is the Bug Tracking System for the POV-Ray project. Before opening a new task, please read How to make a Bug Report
Please do not issue bugs reports against versions earlier than 3.6.
Tasklist
FS#188 - no_reflection broken
Attached to Project: POV-Ray
Opened by Yoshinori Tagawa (y1tagawa) - Wednesday, 05 January 2011, 14:12 GMT
Task Type Definite Bug
Category Backend → Texture/Material/Finish
Status Closed
Assigned To No-one
Operating System Windows XP
Severity High
Priority High
Reported Version 3.70 RC1
Due in Version 3.70 RC2
Due Date Undecided
Percent Complete 100%
Votes 0
Private No
Details
I rendered attached .pov file with both 3.62 and 3.7RC1, and got different output between them.
In 3.7RC1, it looks like no_reflection option of the black sphere doesn’t work.
This task depends upon
Closed by  Christoph Lipka (clipka)
Saturday, 26 February 2011, 00:35 GMT
Reason for closing:  Fixed
Comment by Christoph Lipka (clipka) - Wednesday, 05 January 2011, 17:58 GMT
  • Field changed: Summary (rendered image different between 3.62 and 3.7RC1 → no_reflection broken)
  • Field changed: Status (Unconfirmed → New)
  • Field changed: Category (Backend → Texture/Material/Finish)
  • Field changed: Severity (Medium → High)
  • Field changed: Priority (Normal → High)
From some toying around with the scene, it seems as if POV-Ray is forgetting that it’s tracing a reflected ray when the ray passes through a (semi-)transparent object.
Comment by Christoph Lipka (clipka) - Wednesday, 05 January 2011, 19:27 GMT
  • Field changed: Status (New → Requires testing)
  • Field changed: Due in Version (Undecided → 3.70 RC2)
  • Field changed: Percent Complete (0% → 100%)
should be fixed with change #5350.
Comment by Grimbert Jérôme (Le_Forgeron) - Wednesday, 09 February 2011, 19:19 GMT
Tested with 3.7RC3+ (up to #5402), rendered picture is now like the 3.6.2 one.
Loading...
