The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Opened by Christoph Lipka - 2010-12-18
FS#182 - multi-textured blobs in intersections / differences broken
Multi-textured blobs are broken with 3.7 beta 40 when used inside an intersection, as can be demonstrated by the following scene:
#default { texture { pigment { rgb 1 } } } camera { right x*image_width/image_height location <0,1.5,-4> look_at <0,1,0> } light_source { <500,500,-500> color rgb 1 } difference { blob { threshold 0.6 sphere { < 0.75, 0, 0>, 1, 1 texture { pigment { color red 1 } } } sphere { <-0.375, 0.65, 0>, 1, 1 texture { pigment { color green 1 } } } sphere { <-0.375, -0.65, 0>, 1, 1 } } }
With POV-Ray 3.7.0 beta 40, the entire blob is rendered with the default texture.
The same problem can be seen with “difference” or “merge” instead of “intersection”.
Omitting the CSG “envelope”, using “union”, or assigning the blob to a variable first and then using it inside an intersection, will yield the expected result.
POV-Ray 3.62 renders all variants as expected.
According to initial analysis, the problem appears to be caused by the dual use of the “MULTITEXTURE_FLAG”, which is used in CSG to indicate use of the “cutaway_textures” feature, and in blobs to indicate per-element texturing. (The same flag is also used in meshes to indicate per-face or per-vertex texturing, so similar problems are to expected there.)
My proposal is to use an entirely separate flag for the “cutaway_textures” feature (the blob and mesh can safely continue to share the MULTITEXTURE_FLAG).
fixed with change #5274
Confirmed as fixed with RC2/#5347 from source on linux 64bits.
The scene in the report is ok now.
