POV-Ray
The Persistence of Vision Raytracer (POV-Ray).
This is the Bug Tracking System for the POV-Ray project. Before opening a new task, please read How to make a Bug Report
Please do not issue bugs reports against versions earlier than 3.6.
Tasklist
FS#15 - julia fractal, trace and inside cause crash
Attached to Project: POV-Ray
Opened by Tim Attwood (TimA) - Saturday, 09 May 2009, 22:59 GMT
Task Type Definite Bug
Category Backend → Geometric Primitives
Status Closed
Assigned To Chris Cason (chrisc)
Operating System All
Severity Medium
Priority Normal
Reported Version 3.70 beta 32
Due in Version 3.70 beta 33
Due Date Undecided
Percent Complete 100%
Votes 0
Private No
Details
Using trace or inside with a julia fractal causes a crash.
#declare Test = julia_fractal {
  <-0.083,0.0,-0.83,-0.025>
  quaternion
  cube
  max_iteration 8
  precision 20
#declare Norm = <0,0,0>;
#declare Hit = trace(Test,<0,0,-10>,z,Norm);
#declare Center = inside(Test,<0,0,0>);
This task depends upon
Closed by  Chris Cason (chrisc)
Sunday, 07 June 2009, 09:51 GMT
Reason for closing:  Fixed
Additional comments about closing:  Fixed in change #4811.
Comment by Christoph Lipka (clipka) - Sunday, 10 May 2009, 00:16 GMT
  • Field changed: Status (Unconfirmed → New)
confirmed with beta.32 based development version
Comment by Grimbert Jérôme (Le_Forgeron) - Monday, 11 May 2009, 16:34 GMT
The bug is due to the size of stack in the parser thread (already created) not being updated when the depth needed for a fractal is increased.
When trace is used later, as the intersection stack is too short (in fact, default to none), it's crashing.
Attached is a patch for beta 32 source.
Proposal of at least a workaround (I find it ugly but it works), based on beta 32:
Updating the parser-thread Stack at the same time as the limit of stack is updated.
For rendering threads, they will use, as previously, the stack allocated from the limit.
Why it's ugly: the fractal object need to know about the parser!
Loading...
