The Persistence of Vision Raytracer (POV-Ray).
This is the Bug Tracking System for the POV-Ray project. Before opening a new task, please read How to make a Bug Report
Please do not issue bugs reports against versions earlier than 3.6.
FS#12 - facets pattern in normal map
Attached to Project:
POV-Ray
Opened by Tim Attwood (TimA) - Saturday, 09 May 2009, 22:27 GMT
Last edited by Grimbert Jérôme (Le_Forgeron) - Sunday, 09 September 2012, 17:19 GMT
Details
Using a facet pattern in a normal map results in a unspecified error in Evaluate_TPat at the render stage.
Example:
sphere {
0, 1
texture{
pigment{rgb <1,1,1>}
normal {
facets
normal_map {
[0 bumps ]
[0.5 facets ]
[1 bumps ]
This task depends upon
Closed by Grimbert Jérôme (Le_Forgeron)
Reason for closing: Fixed
Additional comments about closing: Tested with official 3.7RC6: fine, error line is correct, message seems clear.
Confirmed with beta.32 based development version.
Note that the offending construct is “facets normal_map {...}”, not the “facets” statement appearing inside the normal_map block (which can be replaced with e.g. “bozo” with the same effect).
Also note that the render-time abort matches behavior of version 3.6.
What is the status of this?
nothing new from my side; Chris?
I took the liberty to “steal” this task from Chris, and fix this with change #5610 as suggested.
