The Persistence of Vision Raytracer (POV-Ray).
This is the legacy Bug Tracking System for the POV-Ray project. Bugs listed here are being migrated to our github issue tracker. Please refer to that for new reports or updates to existing ones on this system.
Attached to Project: POV-Ray
Opened by Jim Holsenback - 2010-04-21
FS#102 - #switch directive parsing problem
The #switch directive isn’t parsing correctly. In the following construct NO warning or error is generated:
#switch (RF)
case (0) rotate z*355 #break case (144) rotate z*7.5 #break case (216) rotate z*5 #break
RF is a variable passed to the macro in which this construct resides. The first ‘case’ action IS executed, but none of the others are on successive calls to the macro. If I properly add ‘#’ to the second case the 1st and 2nd condition are executed but not the last. If ‘#’ is REMOVED from any of the break directives an error is generated and parsing halts.
POV-Ray's inability to throw an error on the "case (0)" can be cured; actually I have just thrown together a patch that does right that.
As for the other missing "#", that's an entirely different story. (Note that you can put just about anything there without POV-Ray ever complaining, not just "case", "range" or "else".)
change #4946 will cause POV-Ray to issue an error when the first "case" is not preceded by a "#".
This got submitted in beta37 if that's correct I'll close this one .. or maybe you should ... take yer pick!
